02-03-2014 11:04 AM - edited 03-07-2019 05:58 PM
Hello, does anybody know if I can setup a cross-stack LACP between two stacked C2960S-48TS-L(with the additional stack module) ?
If it is, is there any limit (ports or groups limits)?
Thanks a lot,
Ludovic
Solved! Go to Solution.
02-03-2014 11:42 AM
You should be able to do that . On older 2960's they were limited to 6 port channels per box , don't know if that has changed on the newer 2960's or not.
02-03-2014 12:11 PM
Cross Stack LACP is possible.
However you still have there is a limitation to 6 port-channels.
Please go through the following link for details:
Ankur
"Please rate if found useful"
02-03-2014 11:42 AM
02-03-2014 12:11 PM
Ankur
