Webcast-Catalyst9k
LACP etherchannel -interface mode
Hi all,
I created a LACP etherchannel for 3 ports on the switch (in access mode). For port-channel interface, do i need to configure access mode or just leave it that way?
interface GigabitEthernet9/44
description :LB1 eth0
no ip address
switchport
switchport access vlan 111
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
channel-group 20 mode active
interface GigabitEthernet10/19
description :LB1 eth1
no ip address
switchport
interface GigabitEthernet10/31
description ::LB Eth2
no ip address
switchport
interface Port-channel20
description :LACP CHANNEL#20
no ip address
switchport
** do I need below** ?
end
MS
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: LACP etherchannel -interface mode
Hi MS,
Yes, you need theses commands.
regarding your Etherchannel, it is recommend to use even number of interfaces 2, 4, 6, or 8 and not odd numbers. If you use odd numbers, it works fine, but the load balancing may not be distributed evenly.
here is more info:
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
1 REPLY
VIP Super Bronze
Hi MS,
here is more info:
2153
