LACP neighbor Dev ID
1. What is the significance of the LACP Neighbor  "Dev ID"  ?
It looks like it is a combination of  priority.macaddress.
I am seeing some inconsistencies in the output of some show commands on a Cisco CBS3110G (Cisco-IBM Blade switch) runnning IOS version
12.2(53)SE . We have the switch ports configured for "channle-group x mode active". The IBM Blade servers are using the Broadcom Advanced Utility
for building the "teams".
The virutal mac address being used by some of the blade servers were changed by the server admins.
In the output of the "show lacp neighbor" command the "Dev ID" listed still shows the Mac address that was previously in use by the server nic team.
I have deleted the PO interface and rebuilt it. After being rebuilt the PO int still shows the LACP neighbor Dev ID as the previous mac address.
Is there a way to clear the Dev ID for an LACP channel ?
Would the inconsistency cause any network related issue ?
For example
Output of "Show run int g1/0/2" (1st nic in team)
interface GigabitEthernet1/0/2
switchport access vlan 218
switchport mode access
channel-group 2 mode active
Output of "Show run int g2/0/2" (2nd nic in team)
interface GigabitEthernet2/0/2
Output of "Show mac address-table int po2"
R62_VBS3#sho mac address-table int po2
          Mac Address Table
Vlan    Mac Address       Type        Ports
218    0021.5e91.ade0    DYNAMIC     Po2
Output of " Show LACP neighbor" (for channel po2)
R62_VBS3#sho lacp 2 neigh
Flags:  S - Device is requesting Slow LACPDUs
        F - Device is requesting Fast LACPDUs
        A - Device is in Active mode       P - Device is in Passive mode
Channel group 2 neighbors
Partner's information:
                  LACP port                        Admin  Oper   Port    Port
Port      Flags   Priority  Dev ID          Age    key    Key    Number  State
Gi1/0/2   SA      1         0021.5e91.b990  19s    0x0    0x1    0x9     0x3D
Gi2/0/2   SA      1         0021.5e91.b990  19s    0x0    0x1    0xA     0x3D
Thanks in advance for any clarification
John R.
682
