10-23-2015 04:07 AM - edited 03-08-2019 02:21 AM
VSS1#sh etherchannel su
Group Port-channel Protocol Ports
34 Po34(SD) LACP Gi1/1/1(I) Gi2/1/1(I)
VSS2#sh etherchannel su
34 Po34(SD) LACP Gi1/1/4(I) Gi2/1/4(I)
VSS1#sh int po34
Port-channel34 is down, line protocol is down (notconnect)
VSS1#sh int Gi1/1/1
GigabitEthernet1/1/1 is up, line protocol is up (connected)
VSS1#sh int Gi2/1/1
GigabitEthernet2/1/1 is up, line protocol is up (connected)
Why does not the LACP?
10-23-2015 07:42 AM
are you trying to connecting lacp between the 2 6500s in the vss setup or are you connecting to another switch ?
If its between the 2 6500s in vss the port-channel needs to have switch virtual link set under it
can you post your configs of the ports that your trying to connect
10-23-2015 10:20 PM
the problem is solved!
it was the same switch virtual Domain, we get a same LACP sys-id
configure different switch virtual domain and everything works!
thank
10-23-2015 07:48 AM
What does the port-channel 34 interface connect to? All the links are showing with an I (Individual) flag which is typically because the interface is not receiving LACPDU from the downstream device. You can verify this with the show lacp counters command.
This is normally a configuration error on the downstream device where it's not configured for active link aggregation. For example a Cisco switch with the command channel-group group mode on would give this error.
Regard
