LACP - sge2000P to Catalyst 3750
cmlarrieu
Greetings,
Does anyone know if it is possible to configure LACP etherchannel to a Catalyst 3750?  Playing around with the SMB switches for the first time.
I know how to do it on the 3750 but am having trouble figuring out the sge2000p.  Any advice or configs would be helpful.
Carlton
huwyhuwy123
Did you ever figure this out? I have the same issue.
Cheers,
H
Tom Watts
Hi, yes the LAG and LACP is possible.
Remember if the settings do not match EXACTLY, you will broadcast loop the switch and likely lose access to the SGE switch.
However, the LACP options on the SGE switch is very limited, it is either enabled or disabled, nothing in between. If you're looking for only a LAG that is static, I would highly recommend just use an on command and abandon the LACP all together.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
