05-19-2008 07:03 AM - edited 03-05-2019 11:04 PM
Has anyone made this work? Currently have
LACP trunk between two 6509's working fine.
Using two ports on my X6408A-GBIC blade in 6509 to trunk dot1q to two 2950 switches.
Would like to use two more ports on same 6408 blade to LACP to the Linksys.
05-19-2008 08:53 AM
The SRW2048 does support 802.3ad LACP.
(up to 8 ports in up to 8 trunks; per the srw2048 specs)
Please see the following link for more info on SRW2048 functionality:
05-19-2008 09:32 AM
That's great.
Question: The Cisco switch requires setting the entire blade to LACP protocol. Will that
cause me problems with the two ports currently running dot1q(PAgP)to two 2950's?
05-19-2008 09:37 AM
You can have both protocols running on the same module.
HTH,
__
Edison.
