LAN CONNECTIVITY
I  have a branch office where the connection between the LAN switch and Router keeps on going off kindly help. When it times out, then from other branch offices i can be able to reach the router but not the switch directly connected to the router and while in LAN i can reach the switch but not the router.
The timeout remains until i restart the Router or Switch.
The Router is Cisco 1841 and the Switch is Cisco 2960.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
If this is an on-going issue,
If this is an on-going issue, have you ever considered upgrading the IOS?
Note: The timeout lasts until
Am stuck.
Hi Leo, the IOS for the
Hi Leo, the IOS for the switch or router?. I have not tried upgrading the IOS for both although i have tried replacing the switch with a another 2960 but the problem persisted.
The problem has been there for a bout 2 months now.
Upgrade the IOS of the router
Upgrade the IOS of the router first.
67
