12-12-2011 09:57 PM - edited 03-07-2019 03:52 AM
Hi ,
Can anyone please suggest me any looping trouble shooting steps.( Total LAN will be down – One PC could not access other PC in other switch( Not periodically – Twice or thrice in a week) .There are third party switches as well non Cisco IP phone in the setup)
1)
Spanning tree (RSTP ) , BPDU and root guard enabled.
2) No indication of BPDUs in the show logs.
3) There is no much spanning tree topology changes.
4) Also the LAN QoS is enabled and configured for the Non Cisco IP phones.
But if I restart all of my Cisco ( Only Cisco) switches LAN Network will come up and function normally.
Please suggest me any steps to come out apart from enabling the spanning tree debugs.
Sinjish.K
12-13-2011 12:17 AM
hi,
can you tell us a bit more of your topology please. how are things connected?
florian
12-13-2011 12:36 AM
Hi florian,
Please find the network layout in L2 perspective .
The total network consists of 9 numbers of switches .
1) Two core swithes .(One as spanning tree root )
2) Four switches connected to the core as a star topology ( Core 2 is the secondary for the core 1)
3) RSTP and BPDU guard enabled in the switches .
4) Three switches are connected to the core as serially ( One switch to other and terminating in the core )
Sinjish.k
12-13-2011 01:18 AM
Have you checked the cpu utilization at that time?
Also if required enable port security & configure vtp pruning so that unwanted traffic flow can be avoided.
++ enable portfast with bpdu guard globally so that the removal of end device wont affect the entire vlan's mac to get flushed out.
conf t
spanning-tree port-fast default
spanning-tree bpduguard default
Hope this helps.
Cheers
Somu
Rate helpful posts
12-13-2011 02:40 AM
when did you encounter these problems for the first time?
did it ever work fine? was something changed in the network, e.g. new devices, etc.?
do you really have to restart all of your cisco devices to make it work again?
