Webcast-Catalyst9k
LAN performances
Dear ALL,
I've experienced two different tarnsfer speed associated to two switch:
one is a simple 4 ports without administration but with good performances, the other
is a Catalyst 2900 but I think it was not properly configured.
Please could you give me guide lins in order to get good/standard configuration
for switch and ports ?
Alberto Brivio
1 REPLY
Purple
Re: LAN performances
not much to configure , you do have to make sure both the switchports and the pc nics match for speed and duplex . If the switch is auto then the pc or server nic must be auto also.
226
