02-24-2009 11:10 AM - edited 03-06-2019 04:13 AM
Hello experts i have a CISCO old series router of 2500 series the problem which i am facing that this router have no LAN port by default and also do not provide support for modules so please tell me how can i attach my LAN to this router. router has 2 serial ports AUX port and a console port please help me. thanks
Waiting for reply
Best Regards
Ahmad Ellahi
02-24-2009 11:20 AM
sorry, you can not.
02-24-2009 11:29 AM
Maybe you should buy a new router.
02-24-2009 07:53 PM
You can not.
The best you can do is connect one of the serials to another router with a lan port.
02-24-2009 11:43 PM
it's stange to find a router without a lan interface.
has it an AUI port? this a lan interface.
if yes, then you can buy a converter AUI/RJ45
02-25-2009 05:43 AM
02-25-2009 02:27 AM
you do one thing u buy a transreceiver which convert serial interface to RJ45 Female connector using this you can connect 1 Lan connection to your router
regard
sudhendu taklikar
system admin
02-25-2009 05:45 AM
