LAN QoS question
Hello all...wondering if someone can point me to a good link where I can confirm that certain hardware and IOS combinations will support QoS? In particular, the following:
cisco 3750 w/IOS c3750-ipservices-mz.122-25.SEC
cisco 3550 w/IOS c3550-ipservices-mz.122-25.SEE2
cisco 2851 w/IOS c2800nm-spservicesk9-mz.123-11.T5.bin
cisco 2801 w/IOS :c2801-advsecurityk9-mz.124-12.bin
cisco 2811 w/IOS c2800nm-advipservicesk9-mz.124-3.bin
Thanks in advance!!
1 ACCEPTED SOLUTION
Re: LAN QoS question
Sandeep,
Use the following search criteria.
Class-Based Shaping
QoS Packet Marking
Quality of Service (QoS) - Classification Only or Quality of Service (QoS) - Classification and WRED
Quality of Service (QoS) Queuing
Brandon
You can use the Feature Navigator at the following link.
www.cisco.com/go/fn
Click Search by Feature and then type QoS and click Search. This will return many different QoS related features. If there are particular ones you're interested in such as classification, policing, etc., choose them on the left and click Add to add them to the Selected Features on the right. Once you've added the features, click Continue. You can then filter by Release, Platform, etc.
Hope this helps. If so, please rate the post.
Brandon
Hey Brandon....thanks for the reply...I tried that link out, and I keep getting the following error:
The feature combination you searched on is not in any supported Cisco software releases in this tool. Please change the feature combination and search again. Thank you.
That is not what I was hoping for....just looking for basic QoS functionality from the above mentioned device/IOS combinations.
Classification, marking, queueing, and shaping
Any other suggestions?
Thanks again...
Sandeep
Sandeep,
Class-Based Shaping
QoS Packet Marking
Brandon
516
