04-04-2008 02:51 PM - edited 03-05-2019 10:12 PM
Hi all! Is it possible to creat Vlans between a cisco switch and a non cisco switch e.g Extrem switch.?
We need to exten a lan to a little lan that is running on an Extrem switch.We are using the 802.1q on the cisco switches.
Solved! Go to Solution.
04-11-2008 02:08 PM
Hi Kgabo
Can I ask if the Extreme switch is running purely as an L2 switch or has it been licensed to run as an L3 switch? I just ask because of the number of VLAN's configured on the Extreme.
Also can I ask what the configuration line "configure vr VR-Default add ports 1-50" is doing? I am not familiar with this.
Finally, if you want to have traffic from VALN 133 and VLAN 134 pass between the Extreme and the Cisco you will need to create a trunk port on the Extreme. I see from the configurations posted above that you have designated port Fast Ethernet 0/4 on the Cisco as a trunk and allowed VLAN 133 & 134 on this trunk.
Now on the Extreme, which ever port the Cisco will connect to, run the following (assuming Cisco linked ot port 24 on Extreme)
configure vlan 133 add port 24 tagged
configure vlan 134 add port 24 tagged
This would enable port 24 as a IEEE 802.1Q trunk with traffic for VLAN's 133 & 134 allowed across the trunk. Substitute port 24 for the port the Cisco connects to.
Best Regards,
Michael
04-04-2008 02:55 PM
yes it is. Vlans are standard dot1q. The method of tagging frames with vlan ids is standard.
http://www.math.uwaterloo.ca/mfcf/internal/procedures/networks/manuals/Extreme_quick_ref.htm
04-07-2008 05:28 AM
Hi Matt!
Thanx for the Url site. It does not help much as im a cisco guy. Maybe have a look at configs Xtreme and Cisco maybe you can sport the probelm. Pliz Pay attesion to Vlan133 n 134.
Im running EIGRP on my net and he is running OSPF.
EXTREME
GABORSS01.4 # sh configuration
# Module devmgr configuration.
configure snmp sysName "GABORSS01"
configure snmp sysContact "support@extremenetworks.com, +1 888 257 3000"
configure timezone name GMT 120 noautodst
configure slot 1 module X450a-48tdc
configure sys-recovery-level switch reset
# Module vlan configuration.
enable mirroring to port 41
create vlan "ADC"
configure vlan ADC tag 123
create vlan "CHARG_FDT"
configure vlan CHARG_FDT tag 134
create vlan "CHARG_INTOM"
configure vlan CHARG_INTOM tag 227
create vlan "CHARG_RAD"
configure vlan CHARG_RAD tag 240
create vlan "CHARG_RDT"
configure vlan CHARG_RDT tag 133
create vlan "CN_SS7_1"
configure vlan CN_SS7_1 tag 125
configure vlan Default tag 1
create vlan "eDNS"
configure vlan eDNS tag 100
create vlan "EMA_VLAN"
configure vlan EMA_VLAN tag 229
create vlan "Gi_FW"
configure vlan Gi_FW tag 105
create vlan "Gi_l"
configure vlan Gi_l tag 104
create vlan "Gn_FW"
configure vlan Gn_FW tag 102
create vlan "Gn_l"
configure vlan Gn_l tag 101
create vlan "Gom_l"
configure vlan Gom_l tag 120
create vlan "Gp"
configure vlan Gp tag 110
create vlan "iDNS"
configure vlan iDNS tag 103
create vlan "INT_SW_VLAN"
configure vlan INT_SW_VLAN tag 124
create vlan "Internet_VLAN"
configure vlan Internet_VLAN tag 107
create vlan "MIEP"
configure vlan MIEP tag 121
create vlan "OAM_CPC_VLAN"
configure vlan OAM_CPC_VLAN tag 122
create vlan "OAM_MPBN"
configure vlan OAM_MPBN tag 108
create vlan "RADIUS_VLAN"
configure vlan RADIUS_VLAN tag 106
create vlan "RSG_VLAN"
configure vlan RSG_VLAN tag 228
create vlan "SMS_VMS_VLAN"
configure vlan SMS_VMS_VLAN tag 119
create vlan "SS7_l"
configure vlan SS7_l tag 109
CISCO
Current configuration : 1245 bytes
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
enable secret xxx
ip subnet-zero
interface FastEthernet0/1
switchport mode trunk
no ip address
interface FastEthernet0/2
switchport access vlan 128
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
switchport trunk allowed vlan 133,134
no ip address
interface FastEthernet0/5
switchport access vlan 134
no ip address
interface FastEthernet0/6
switchport access vlan 133
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
switchport access vlan 135
no ip address
interface FastEthernet0/9
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface Vlan1
ip address 10.1.31.205 255.255.240.0
no ip route-cache
no ip http server
line con 0
password
login
line vty 0 4
password
login
line vty 5 15
login
end
Switch#
Switch#
Switch#
Switch#
04-11-2008 02:08 PM
Hi Kgabo
Best Regards,
Michael
