08-19-2014 06:45 AM - edited 03-07-2019 08:26 PM
Their is one wierd issue that I am having. I have a port which is configured as access vlan for a server. It was working before but since the server team has reset the nic the ip on that nic is not pingable. The port is showing up and mac is learning from the right vlan but I am not able to ping it from the directly connected switch, though its pingable from core switch.
One more thing is that there is no input output rate but the packets output and bytes are incrementing.
switch 1#sh int GigabitEthernet6/0/9
GigabitEthernet6/0/9 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0023.ead5.da89 (bia 0023.ead5.da89)
Description: st-w1061-nlb
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 0/255 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseX
Media-type configured as connector
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:48, output hang never
Last clearing of "show interface" counters 1d02h
Queueing strategy: fifo
Output queue: 0/40 (size/max)
203145 packets input, 177989285 bytes, 0 no buffer <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Received 101588 broadcasts (13009 multicasts)
0 watchdog, 13009 multicast, 0 pause input
38601730 packets output, 16650629772 bytes, 0 underruns <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Can anybody help me on this.
08-19-2014 07:38 AM
Are the core switch and this one sourcing pings from the same L2 network?
08-19-2014 07:45 AM
Different, the server is connected directly to the edge switch through the above mentioned port and core and edge switch is connected through ten gig interface. Anything related to incrementing output packet and bytes.
08-20-2014 02:59 AM
It's odd that the server is pingable from your core, but not from your access switch. Can you provide the output of a 'show mac add' from the access switch port, a 'show arp | inc' for the IP of the server on the core, and a ping from both devices highlighting the source interface that you're using? I take it that there are other servers on the same access switch and same VLAN that you CAN ping?
08-19-2014 02:02 PM
Hi anujsinghi_84,
Please check your default-gateway is configured correctly on the access-switch, I assume switch is configured in layer2 mode where server is connected.
thanks
Rizwan Rafeek
08-20-2014 02:51 AM
The default gateway is configured fine . All the servers on that switch are working fine and we have problem with one of the server nics connected to this port so I am guessing for any port problem if anyone could tell me.
