LAN switching
pruthviraj
I want to bind mac addresses of hosts with Ip addresses at switch or router
provide me the configuration details
bmath
Mre you talking about Mac security?
ankbhasi
Hi Friend,
I believe you want to have a static ARP entry on your switch/router?
If yes
switch(config)#arp
Have a look at this link
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tiad_r/adrarpht.htm#wp1158390
Ankur
*Pls rate helpfull post
thank you very much
andrew.burns
Level 7
Level 7
Sounds like you are looking for the "arp" command, here's an example for ethernet:
arp 10.31.7.19 0800.0900.1834 arpa
HTH - plz rate if useful
Andrew.
