Webcast-Catalyst9k
LAN unreachable problem
We configured the VLANs in 3750, 2960 Switches.The problem is that out of 150 users only 7-10 users are not getting ip addresses through DHCP as well as statically. 90 % users of one switch are properly getting the network but few users on same switch are not able to get the network.pls help us.
Re: LAN unreachable problem
Hi Parba,
There is several things to verify.
1. check the VLAN on switch interfaces for your users, that can't be reached
2. check if that VLAN is in the trunk towards your rotuer
3. if your DHCP server is not on the same VLAN as your guests, verify ip helper address poiting to your DHCP server
On your switch:
do sh vlan to see, if the vlan is created
do sh interface status to see, if the correct VLAN is assigned to correct interfaces
do sh run int XY - the interface, where your users are connected (the problematic one)
If possible, post the outputs
Ivan
[rate any helpful posts]
Purple
Also make sure portfast is turned on for all user ports.
119
