Community Member
laptop/switchport
need to learn steps to add a laptop to a switch vlan. CATOS
Hall of Fame Super Blue
Re: laptop/switchport
To allocate a port into a vlan on a CatOS based switch eg.
Port = 3/5
vlan = 10
From enable mode
set vlan 10 3/5
Hope this is what you were asking
Jon
Community Member
jon,
thank you for your reply. sorry I was no clear with my question.
I want to know how to add my laptop to participate in one of the vlans.
thank you.
Purple
you have to know where your laptop is plugged into the switch . Vlan assignment is done on a per port assignement on the switch itself. There is nothing on the laptop itself you can do to put it into a particular vlan .
Community Member
Glen,
Thank you for your reply.
want the laptop to be part of vlan2 (ports 2/1-2) I want to be able to plug the laptop to port 2/1. how can I achieve that?
your help is very appreciated
Purple
You will have to talk to your network guy and find out where the laptop is plugged in. you then assign vlan 2 to those ports , in your case ports 2/1-2 . If IOS switches then issue switchport access vlan 2 on the ports , if catos then it would be set vlan 2 2/1-2 .
120
