Community Member
last reset from s/w reset
i am getting this error "
last reset from s/w reset" in the sh ver ,some switches were rebooted without  any reason or cause,there is no crashinfo or logs .
Pls find the  sh stack output .can we know the reason of restart.
sho stack
Minimum process stacks:
Free/Size   Name
5696/6000   OIR IOS Process
5652/6000   ISSU Infra API Delayed Registration Process
5608/6000   VS CHASSIS Info
2976/6000   IPC ISSU Versioning Process
2708/6000   IPC ISSU Receive Process
5540/6000   IPC Zone Manager
5680/6000   ICC Retry Q
4020/6000   IPC Split Init
3456/6000   ICC Nego Client
3540/6000   NTI Trigger Instance for EP ID 0x5
5692/6000   CDP BLOB
5332/6000   C6K_POWER_Process
3500/6000   eobc_init_process
  928/3000   mcm_ipc_slave_open_session_to_master_process
5552/6000   PM MP Process
10732/12000  EARL INFO CAPABILITY process
5520/6000   Cat6k Stack MIB Init
5296/6000   C6K ENV RP init
2968/6000   c6k ivrfs
4740/6000   SPAN Subsystem
5380/6000   PostOfficeNet
52756/60000  EEM TCL Proc
54764/60000  EEM Auto Registration Proc
5504/6000   SASL MAIN
11432/12000  Router Init
11692/12000  cdp init process
4844/6000   Draco DFS Port Registation Proc
5356/6000   RADIUS INITCONFIG
3548/6000   IPC LC Port Opener
5684/6000   MPLS ACL RP CFG Background
5300/6000   TRANGE RP POPULATE NEW PROC
5144/6000   IP ACL RP Background
4484/6000   LCC Configure
5180/6000   SLB RF Active Proc
2676/6000   draco-oir-process:slot 5
3676/6000   draco-oir-process:slot 3
3676/6000   draco-oir-process:slot 8
3680/6000   draco-oir-process:slot 2
3680/6000   draco-oir-process:slot 7
2744/6000   NTI Trigger Instance for EP ID 0x1
5632/6000   URPF stats
3676/6000   draco-oir-process:slot 4
6588/12000  Init
3676/6000   draco-oir-process:slot 1
5520/6000   Link Status process
7780/12000  SSH Process
Interrupt level stacks:
Level    Called Unused/Size  Name
  1      783216   7460/9000  Inband Interrupt
  2    87880452   7112/9000  EOBC Interrupt
  3      164690   8460/9000  Management Interrupt
  4         388   8600/9000  Console Uart
  5           0   9000/9000  Mistral Error Interrupt
  7    41144160   8552/9000  NMI Interrupt Handler
******* Information of Last System Crash **********
Using bootflash:crashinfo_RP.
%Error opening bootflash:crashinfo_RP (File not found)
****** Information of Last System Crash - SP ******
Everyone's tags (2)
Balbir,
Can you provide me show tech output from the switch?
Inayath
Community Member
Re: last reset from s/w reset
Pls find the sh tech of 2 switches which rebooted
672
