layer 2 or layer 3 issue ? (diagram added)
tdanetsco
Hi everybody,
in order to connect a LAN to 02 redundant routers like the attached diagram, the question is when the port Gi0/1 in 2960 switch is active and Gi0/2 is blocked, all the 03 devices are reachable (respond to ping) and traffic goes through, but when port Gi0/1 is DOWN and the port Gi0/2 is active, the routers are not rechable from 2960 switch and no traffic is possible between switch and routers.
any suggestions ?
thanks.
5 Replies 5
gilesc
You would need to set a virutal IP address for the two routers
e.g.
interface vlan 300
ip address 192.168.12.3
standby ip 192.168.12.1
This would create a virtual router which you then point the clients towards if either router fails the HSRP protocol will readvertise the address out the other router.
As posted above you need a gateway redundancy protocol like HSRP to work
Have a look at this link
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_12c_ea1/configuration/guide/swhsrp.html
Narayan
happy new year !
i have configured HSRP between the two routers, but the problem is always the same,
any idea.
thanks.
Can you post configs of 2 routers and the switch.
Also when you configured HSRP did you make the default-gateway on the switch point to the Virtual IP address you configured under HSRP ?
Jon
Hi jon,
you can find the configurations in the attached file.
BR,
