01-14-2012 07:59 AM - edited 03-07-2019 04:21 AM
Need to prevent unauthorized users from getting IP address from DHCP when connected to our wired network.
In few remote sites we run DHCP for voice & data in the router where only limited users (around 30)are operating. We dont have IT assistance in those sites.
Our business is automotive and we let customers/users to our premise. We need to block the unauthorized user from using our network.
Any configuration can be done in the cisco access switch level?
Thanks in advance...
01-14-2012 08:27 AM
You can try deploying DHCP snooping.
here is a link for your reference:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.1/12ew/configuration/guide/dhcp.pdf
01-14-2012 09:08 AM
Hi Reza,
I don't think DHCP snooping could prevent users from getting an address from the server as its goal is to prevent unauthorized DHCP servers and eventually rate)limit the client requests.
I think that dot1x should be more appropriate for this case.
Regards.
Alain
01-14-2012 09:29 AM
Hi Alain,
I beleive that is the best option for which we require an authentication server. Any other possibility without the AAA server.
Reagrds,
Raffi...
01-14-2012 10:09 AM
you can enable port security on switch port and limit it to only one approved mac address
