Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
layer 2 trunk ports went down due to cisco 4500 core switch !!!
Hi Everyone,
My 2 Layer 2 2960 switchTrunk Ports went down due to cisco 4500 switch. It happening everytime . I rebbot the switch 4500 . then problem disappears but after sometime facing same issue.
Please help.
Silver
Re: layer 2 trunk ports went down due to cisco 4500 core switch
When you say that the ports went down you mean that you lost connecitvity? Do you see any errors on the logs? Can you may be post the running configuration of the interfaces involved from both switches?
VIP Super Bronze
Can you provide a little more info on how these switches are connected together?
Can you also post "sh run" from both switches?
Better i can provide complete logs and sh run interface output by tomorrow . thanks for the interest.
can it be spanning tree loop issue.???? that making the other device trunk ports down.
VIP Super Bronze
Hard to tell without a drawing and config, but It sounds like a spanning tree issue.
Hall of Fame Super Gold
Hmmmm ... You won't be able to determine anything if you won't provide any addition information.  I mean what do you mean by "went down"?  Did the port go into "error disable"?
If it went into error disable, console in both switches and post the output to the command "sh interface status err".
180
