Community Member
Layer 3 routing and WS-X45-SUP6-E
New in an environment and getting some equipment up and running.  I have a WS-X45-SUP6-E and im trying to enable simple layer 3 routing between vlans.  When I run the ip routing command it doesn't seem to take.   Was doing some reading and it seems like Cisco has changed some things around and now if I want to do layer 3 routing I need to purchase an additional license for this functionality?  Am I reading this correctly?
The device is currently running cat4500e-ipbasek9-mz.152-2.E.bin, its not in production yet so im flexible if I need to change IOS
VIP Super Bronze
What is your license level
What is your license level?
post the output of "show license"
Community Member
That is the thing, when I try
That is the thing, when I try to check it doesnt seem to know that command
#show license
% Invalid input detected at '^' marker.
Here is my show module:
#show module
Chassis Type : WS-C4507R-E
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
 1    48  10/100/1000BaseT Premium POE E Series  WS-X4648-RJ45V+E
 3     6  Sup 6-E 10GE (X2), 1000BaseX (SFP)     WS-X45-SUP6-E
Hall of Fame Super Gold
Go HERE and scroll down to
Go HERE and scroll down to Table 1.  It should tell you which routing protocols are supported in IP Base and Enterprise.
217
