Layer 3 Switch and Multicasts
We have a Cisco 4948 Switch which appears to be sending Multicast traffic outside of its intended VLAN and consequently flooding an external network.  Perhaps I am missing a configuration to restrict this traffic. Can you help?
~~c
3 ACCEPTED SOLUTIONS
Re: Layer 3 Switch and Multicasts
without the config, I can only guess. But you can try to set the storm-control multicast level or see the following page:
https://www.cisco.com/en/US/docs/ios/ipmulti/configuration/guide/imc_cfg_rpgmp_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Maybe it helps you
Martin
Hall of Fame Super Blue
~~c
As Jerry says, config would be useful but some questions -
1) Is the 4948 responsible for L3 inter-vlan routing ?
2) if 1) then have you enabled ip multicast routing on the switch
3) if 2) have you enabled PIM on any of the vlan interfaces and if so which PIM, sparse or dense mode ?
4) Do you have any receivers that are not in the intended vlan ?
Be aware that PIM dense mode is a flood and prune technology so it will send the multicast traffic onto any vlan that has PIM enabled. If you want to avoid this you could either -
1) use PIM sparse mode which does not use flood and prune
2) if you only need multicast within the actual vlan then disable multicast routing and use IGMP snooping querier on that L3 vlan interface.
Jon
You can remove sparse-dense-mode on the VLAN that you don't want multicast traffic to be received. To contain the multicast traffic in a single L2 VLAN, you can leave ip pim sparse-dense-mode configured or like what you said, configured igmp snooping querier. This should do the trick.
HTH,
jerry
Can you post the config and detail explaining what is happening?
jerry
Maybe it helps you
Martin
~~c
Jon
Jon,
We do have inter vlan routing configured.  We also have ip pim sparse-dense-mode configured on two of the three VLANs.  Just to be clear, if I wanted Multicast within only one VLAN should I remove the ip pim sparse-dense-mode from other VLAN interfaces, and then enable IGMP snooping querier on that VLAN interface as well?  Also, I have found the problem with the unwanted traffic.  An engineer connected to the wrong VLAN.  Actually he connected to the VLAN which has the Multicast Traffic.  I guess it was user error in this case.  Thanks for the useful information.
HTH,
jerry
464
