06-10-2014 03:08 PM - edited 03-07-2019 07:42 PM
How does a DHCP server give a requesting “”workstation an IP address”” if each computer (server, workstation) are on two different subnets, ??? if server and workstation are connected into one Layer 3 switch.
Solved! Go to Solution.
06-10-2014 03:22 PM
Have a look at this document:
If the server and workstation are on 2 different subnets and the DHCP server is in the server subnet you need to add an ip helper-address command to the workstation vlan interface
http://www.cisco.com/c/en/us/support/docs/ip/dynamic-address-allocation-resolution/27470-100.html
06-10-2014 03:22 PM
06-10-2014 05:00 PM
Sorry I made a mistake. I read the rest of the link. You are right. it appears in this case a DHCP service scope would be needed for each different subnet, then the different L3 vlans can communicate. Also the DHCP relay agent would also need to be used.
06-11-2014 06:40 PM
This is what I used for the answer.
http://chinnychukwudozie.com/2013/09/26/configuring-intervlan-routing-on-a-layer-3-switch-and-providing-dhcp-to-multiple-subnets-part-1/
