Layer 3 switch vs Router for terminating ISP link
Peter Coggle
I am a newbie to the world of routing and switching.
Our company is planning to start a new site and the internet service provider is providing a 100 Mbps link.
I am confused about the options about where to terminate the ISP link.
Can I terminate it on the layer 3 switch 3750X (which will also be the core switch for the remote site)?
or should I need to buy a new 3925 router to terminate the ISP link?
What are the general guidelines to decide? Can you please help?
Pete
2 Accepted Solutions
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
For a general guideline, you select hardware to meet both performance and feature requirements.  ISRs have a much, much richer feature set than L3 switches like the 3750X.  Without knowing what your feature requirements might be, I would lean toward the 3925.
Martin Carr
Level 4
Level 4
You need a router, your switch does not support NAT.
I suspect you have been presented with a RJ45?
Martin
6 Replies 6
Joseph W. Doherty
Disclaimer
Posting
Thanks a lot Joseph
Is there a tool I can use to decide if I get more details on the requirements?
Pete
Disclaimer
Posting
The feature navigator tool (support contract requirement?) might be used, but you normally start with your requirements and then see if they are met.
PS:
An example is what Martin mentions, i.e. routers generally offer NAT and "small" L3 switches, like your 3750X do not.  What we don't know is whether you'll need NAT, although there's a good chance you will if want your LAN users to have Internet access and if you don't have any other appliances.
Another example might be site-to-site VPN, again you'll find this feature on most routers but not on most "small" L3 switches.
Martin Carr
Level 4
Level 4
Martin
Thanks Martin
adawa
Level 3
Level 3
Hello, Peter. ISR would be the best solution in order for you to support NAT. Check this link for a comparison of ISR that can suit your requirements. (http://cs.co/9009i00N). Please send me an e-mail (adawa@cisco.com) if you have additional concerns or need local Cisco support. Kind regards and hope this helps!
