04-08-2014 01:47 AM - edited 03-07-2019 07:01 PM
hi All,
I've 2 Q's I'd like some help with
Really appreciate any help with this.
Cheers,
Huw
04-08-2014 02:03 AM
I think that X series of switches have "IP lite" version (something like 2960-XR) which have most of L3 functionality.
Upgrade from one IOS (LAN lite to LAN Base or IP lite) is not supported - you have to buy in start adequate version...
BR,
Dragan
04-08-2014 02:06 AM
Thanks Dragan. So just to make sure I've understood, are you saying we can't upgrade the WS-C2960X-48FPD-L and will need to buy new switches?
Cheers,
H
04-08-2014 02:12 AM
You can't upgrade - and you need XR 2960 switch...
BTW you can do static routing and intervlan routing with LAN base if thats enough for you..."sdm prefer lanbase-routing"
BR,
Dragan
04-08-2014 02:13 AM
Best regards,
XLG.
