Limint number of VLAN-s in QinQ
Branimir Turk
Hi everybody,
Is there any way to limit number of C(ustomer)-VLANs on QinQ tunnel port?
For example, only VLANS 10-20 are double tagged, all other traffic is dropped.
Branimir
Giuseppe Larosa
Hello Branimir,
as far as I know this is not possible: you cannot choice what vlan-ids have to be tunneled and what should be filtered/stopped.
all vlan-tags presented to the dot1q tunnel interface are externally tagged with the service provider tag for this customer.
This is for forwarding efficiency.
see for example this chapter from config guide of C3750
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swtunnel.html#wp1010370
Hope to help
Giuseppe
6 Replies 6
Giuseppe Larosa
Hello Branimir,
Hope to help
Giuseppe
Hi Giuseppe,
Thank you for the information.
Branimir
guruprasadr
Level 7
Level 7
HI Branimir, [Pls RATE if HELPS]
Please let us know the requirement in detail.
Let us assume the Setup as:
BaseStation Switch==>Tunneling Switch ==> Core Switch ==> Edge RouterA.
Configuration for the QnQ Tag Interface at Tunneling Switch:
interface FastEthernet0/20
description For Edge RouterA
switchport access vlan 900
switchport mode dot1q-tunnel
speed 100
duplex full
no cdp enable
spanning-tree portfast trunk
spanning-tree bpdufilter enable
end
Note: VLAN 900 is the QnQ Tag VLAN ID.
BaseStation Switch <> Tunnelling Switch.
If the C(ustomer) VLANS eg: 30-40 are not allowed in the X-connected Interface towards the Tunneling Switch means; the VLANS are not Tagged and hence it is dropped.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
If i understood correctly, you are saying that i need to configure trunk port on BaseStation Switch with switchport allowed vlan 30-40.
Unfortunately BaseStation switch is not under my administration.
HI branimirturk, [Pls RATE if HELPS]
If you do not want VLAN Range 30 - 40 on QnQ path;
Don't allow VLAN 30 - 40 in the BaseStation Switch <> Tunnelling Switch.
Hope I am Informative.
Best Regards,
Guru Prasad R
Thank you,
Branimir
