Webcast-Catalyst9k
Limit bandwidth consumption
Is there a way to limit the bandwidth consumption for each user on the network? I am currently using a Cisco 3750 and was wonder if there is a solution for limiting user bandwidth consumption.
Re: Limit bandwidth consumption
hello
i think this is a real tough thing to do with the 3750's.. even if you have an external shaping device, it is always advicible to put people into seperate domains/vlans and then restrict bandwidth for that zone as a whole.. this will save a lot of time and minimize management....
you can check this URL for configuring the various qos features supported by 3750...
hope this helps.. all the best..
Raj
Actually, what I really wanted was to limit each user to 5 Mbytes of downstream traffic, anything exceeding that limit would stop the user from downloading anymore.
if you are really looking at a cumulative bandwidth download, i think it is not possible with 3750.. 3750's can anyway support aaa accounting... hence, u can take the output to another featured accounting server, which can give these statistics, but its a real hard task.. this is how any ISP would restrict user based downloads , which is quite complex..
Raj
250
