03-26-2007 01:18 PM - edited 03-05-2019 03:06 PM
We want to share an Internet-connection with a C2960 and limit the bandwith on each port (each customer on a port).
I try the parameter "max-reserved-bandwidth" on an interface but there was no difference in bandwith on this port.
Is there a way to limit the bandwith on a switch-port?
Or are there other opportunities?
Thanks!
03-26-2007 02:12 PM
You can limit the connection by police or shape the traffic based on customer requirments or you can use rate limt command.
For max-reserved-bandwidth is just how much you will remain for routing and other issue which is by default 75%.
I hope this is inforamtive for you and rate if it is.
B.R
Ahmadabuzayyad
03-27-2007 08:17 AM
Thanks for the information.
I will explain a bit more....
We haven an Internetconnection of 10 Mb, connected on a C2960 switch. We want to limit the bandwidth on each switch-port to 1 Mbps.
What is the best command we can use on the switch? Do you have some examples for me? (I am not a Cisco specialist)
Thanks!
03-27-2007 08:43 AM
if the 2960 is capable of Layer 3 switching (meaning routing) you could use a CAR policy. Commited Access Rate.
The Committed Access Rate (CAR) and Distributed CAR (DCAR) services limit the input or output transmission rate on an interface or subinterface based on a flexible set of criteria.
you can use the rate-limit command on the interface.
03-27-2007 08:51 AM
I think interface rate-limiting isn't supported on the 2960, specificaly IOS 12.2(25)SEE
See ref.
http://www.cisco.com/en/US/products/ps6406/products_configuration_guide_chapter09186a00805a7620.html
03-27-2007 08:52 AM
Although CISCO does provide contradictory info
http://www.cisco.com/en/US/products/ps6406/products_qanda_item0900aecd80322c37.shtml
03-27-2007 08:55 AM
Please ignore my hastily summarized posts.
03-27-2007 10:02 AM
You can use policing and shaping on the switch ports to achieve the same. Please see the link below of configuring the same:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2960/12225see/scg/swqos.htm#wp1408392
HTH,
-amit singh
