06-09-2007 01:26 AM - edited 03-05-2019 04:36 PM
Hi guys,
Is there a limit on adding more than 3 logging servers on a CatOS Switch. I am trying to add a logging server and I am getting this message "System logging server table is full". Is there a way to increase the limit to add more than 3 logging entries or thats the max it can take. Any tips or suggestions on this appreciated.
TIA
Faiz
06-09-2007 02:11 AM
Hi Faiz,
Using the "set logging server ip_addr" command, you can configure a maximum of three syslog servers at any time.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
06-09-2007 02:24 AM
Hi Mahmoud,
Thanks for the reply, but thats what I've asked, whether I can add a fourth syslog server IP by any way.
TIA
Faiz
06-09-2007 02:35 AM
Sorry if my answer was misleading, but i meant that no you can't, and i don't think that it can be increased in any way.
HTH,
Mohammed Mahmoud.
