11-04-2009 02:45 AM - edited 03-06-2019 08:26 AM
We are facing the following problem. We have a gigabit/optical port on which we want to limit traffic. The port is configured as switchport. The only option about speed is "speed nonenegotiate". What can be a work around to this problem?
Thanks in advance,
Katerina
11-04-2009 03:28 AM
What particular model device and installed IOS version?
11-04-2009 04:27 AM
cisco WS-C6513 (R7000) running "sup-bootdisk:s3223-ipbasek9_wan-vz.122-18.SXF8.bin"
11-04-2009 04:31 AM
What kind of line card is the port on?
11-04-2009 05:23 AM
WS-SUP32-GE-3B
11-04-2009 07:03 AM
If you could upgrade your IOS to 12.2(25) or later, I believe you could use the "srr-queue bandwidth" command at the interface level.
Otherwise I believe it is necessary to use QoS/CoS features as described here: http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bf98.shtml
Hope this helps.
11-05-2009 06:06 AM
11-06-2009 02:49 AM
Thank you all for your interesting links. I will have a look and hopefully find the solution. The thing is that since the switch is very critical and it's difficult to reload, upgrading the IOS is out of the question. So I have I find a solution in the links.
Thnx,
Katerina
