Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Limitations to the Number of Switches in a Ring?
In the Ethernet to the Factory Floor Design and Implementation Guide (version 1.2) it states that the maximum number of bridge devices between two devices on the network cannot exceed seven (with 802.1d RSTP). However on page A-1 it talks about - and provides tests results from a ring topology consisting of eight 2955's and a 3750 - which gives 9 hops. If I understand correctly, one is based on 802.1d and the other is 802.1w.
Are there any limitations to the number of devices in an 802.1w process? Where can I find out what the maximum number of switches which can be placed in a ring? I'm planning to use IE3000 / Stratix 8000.
Thanks for your help.
1 REPLY
Silver
Re: Limitations to the Number of Switches in a Ring?
237
