Limiting GE ports to 10/100
Hi All,
I have a number of 3560 Catalyst switches, and for network design reasons, would like each copper port to act as an autonegotiate 10/100 switch without GE being and option.
Is there a waqy to do this? I can only seem to configure either 10 or 100 or 1000 via the speed command. Any clues?
Re: Limiting GE ports to 10/100
Ada,
Autonegotiate command is used, when you dont know the speed of other side port.
You cannot autonegotiate with 10/100 on GE port. Either you need to set 100 or 10 with speed command.
And anyway I dont think there are any more devices which are comming with 10Mbps interfaces. right.
Hope that helps,
Please rate if helpfull.
Suresh Jain
Not so, Suresh. From Command Ref doc:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225see/cr/cli3.htm#wp1947308
This example shows how to set a port to autonegotiate at only 10 or 100 Mbps:
Switch(config)# interface gigabitethernet0/1
Switch(config-if)# speed auto 10 100
thanks for letting me know my mistake.
161
