Community Member
line card for 4507R+E
Hi Can you help me I have a switch 4507R+E with a supervisor line card WS-X45-SUP6L-E.
I will need a sfp line card so I was thinking in a WS-X4612-SFP-E the doubt that I have is
if Can I install this line card without turn off the switch??
Thanks...
1 REPLY
VIP Super Bronze
Yes, you can insert the card without turning off the switch.  All the cards are hot swapable, meaning you can insert them or take them out or the chassis without the need to reboot or turn off the switch.
151
