Line Cards options for a 4507
Hi all,
I need some info on line cards for a 4507. I have dual Sup IV's. I need 24 fiber gig ports. My dilemma is whether I should use a 4418 or 4 4306 line cards. If I use the 4418 is there a backplane throughput issues? Any info would be greatly appreciated.
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: Line Cards options for a 4507
Wayne
It totally depends on the throughput you need from each port. Bear in mind each line card has access to 6Gbps of the switch fabric with a non-E 4500 chassis.
So there is no oversubscription with the 4306 ie. each port can run at full wire rate. But with the 4418 card 2 of the ports will run at wire rate and the other 16 ports are oversubscribed 4:1. Have a look at Table 2 in this doc for details -
http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea.html
Jon
1 REPLY
Wayne
Jon
517
