Community Member
Line redundacy for data comminucation between Remote Branch and Central Office
Hello Expert,
I currently have a fully functional network consist of Hub (central office) and
8 spokes (remote branch office)
I am using cisco DMVPN for all tunnel communications.
I am about to introduce a second Telco for redundancy, hence for clarity I will refer
Primary Telco as TELCO1 and secondary Telco as TELCO2
The HUB ROUTER INFO
CISCO 2900 series
3 Gigabit Ethernet ports onboard.
4 port switch card.
One of the Gigabit Ethernet port (GigabitEthernet0/1) is use as the wan interface for TELCO1
The 4 port switch card is use for lan interface.
I plan to use a free Gigabit Ethernet port (GigabitEthernet0/2) for the second TELCO2
Interface GigabitEthernet0/1 ------------------------------------ Telco1
description Ip_Dsl Interface$ETH-WAN$
ip address 10.xx.xx.11 255.255.255.0
duplex auto
speed auto
media-type rj45 auto-failover
Interface GigabitEthernet0/2 ------------------------------------ telco2
no ip address
shutdown
duplex auto
speed auto
SPOKE ROUTERS
CISC0 2811 series
2 fast Ethernet ports onboard.
4 port switch card
One of the Fast Ethernet port (FastEthernet0/0) is use as the wan interface for TELCO1
The 4 port switch card is use for the lan interface.
I plan to use a free Fastethenet port (FastEthernet0/1) for the second TELCO2.
interface FastEthernet0/0
description Corriverton Lan Interface$ETH-LAN$
ip address 10.xx.xx.16 255.255.255.0 ----------------------------------- telco1
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1------------------------------------------------- telco2
description $ETH-WAN$
no ip address
shutdown
duplex auto
speed auto
CURRENT DMMVPN TUNNEL SETUP for HUB
interface Tunnel0
description Ip_Dsl Tunnel to remote Locations
bandwidth 2048
ip address 172.168.XXX.11 255.255.255.0
no ip redirects
ip mtu 1500
ip nhrp authentication testvpn
ip nhrp map multicast dynamic
ip nhrp network-id 100000
ip nhrp holdtime 360
ip tcp adjust-mss 1360
no ip split-horizon eigrp 1
delay 1000
keepalive 5 2
tunnel source GigabitEthernet0/1         ---------------------------------- (telco1)
tunnel mode gre multipoint
tunnel key 100000
tunnel protection ipsec profile CiscoCP_Profile
CURRENT DMVPN TUNNEL SETUP FOR REMOTE BRANCH
interface Tunnel0
description Tunnel to Head Office
bandwidth 1000
ip address 172.168.xxx.16 255.255.255.0
ip mtu 1500
ip nhrp map 172.168.XXX.11 10.xx.xx.11
ip nhrp map multicast 10.xx.xx.11
ip nhrp nhs 172.168.XXX.11
delay 1000
keepalive 5 2
tunnel source FastEthernet0/1         ------------------------------------------ (telco1)
tunnel key 100000
tunnel protection ipsec profile CiscoCP_Profile1
Question
I want to use the same DMVPN tunnel from central office to remote Branch for the failover to second telco (telco2)
How do i incorporate second tunnel source in both the hub and remote branch dmvpn tunnel config ?
Note the entire config for both hub and spoke was done using cisco sdm.
This gui utility does not support setting up multiple dmvpn on the same router,hence instead of configing a another dmvpn for
the second telco (telco) communication I am trying to use the existing dmvpn for both primary and failover communication.
Jomo
Re: Line redundacy for data comminucation between Remote Branch
First, is the second telco providing Internet access?
Second, look for doc id 41940 on the. Cisco site.
Community Member
Hello Jeff,
The second telco will not be providing internet access, all the respective telcos will be providing just a connection from
Remote Location to Central office--- Internet etc is handle by a different arrangment.
Jomo
the doc Id I sent earlier will cover it regardless.
Community Member
Hello Jeff,
I went thru the document and cannot fiind any reference how to include the second lan interface on the router
which is  telco 2 connection.
Is there any way I can add FastEthernet0/2  ---------------------------- telco 2 to the config.
I know for Hub failover you have to add the following to spoke tunnel
ip nhrp map
ip nhrp nrp
and you will be able to connect to primary and secondary hub.
I am thinking if a similar entries can be made on the the tunnel config  to point to FastEthenet 0/1 and FastEtherbet0/2
interface Tunnel0
bandwidth 1000
ip mtu 1500
delay 1000
keepalive 5 2
tunnel key 100000
Jomo
I’m not looking right at it, but I believe you are expected to create a new tunnel and bind that to the new interface. Look at the last few pages of the document that discusses failover DMVPN.
239
