Webcast-Catalyst9k
Link between Cisco C4506-E & C2950 is down when speed & duplex is NOT Auto
Hi All
I have C2950 running with 12.1(22)EA13 having uplinks connected to C4506-E (1) & C4506-E (2) 15.0(2)SG.
Speed and duplex are default settings [Speed is auto & duplex is full]. Link between C4506E(1) Gi2/35 <<-->> C2950 Gi 0/1 is negotiated to Speed 1000 & Duplex full. Whereas other link C4506E(2) Gi 2/35 <<-->> C2950 Gi 0/2 is negotiated to Speed 100 & Duplex full.
I tried to configure link C4506E(2) Gi 2/35 <<-->> C2950 Gi 0/2 manual negotiation with speed 1000 & duplex full on both the end interfaces and found link is down.
Why one uplink negotiation happened to be 100 when other is negotiated to 1000 ?
Is there any bug identified with the current running IOS.?
Need help is fixing the problem.
Thanks in advance.
Everyone's tags (2)
Hall of Fame Super Gold
What happens if you set the link to 100 Mbps only?
Re: Link between Cisco C4506-E & C2950 is down when speed & dupl
I have configured MST with two instances and planned that C4506E(1) should be root for MST 10 and C4506E(2) is root for MST 11.
Due to this problem, i see that  STP for C2950 Gi 0/2 is in blocking state
XXXX-XXXX#sh spanning-tree root
                                        Root Hello Max Fwd
MST Instance           Root ID          Cost  Time Age Dly  Root Port
MST00            24576 8843.e1bd.6a00      0    2   20  15  Gi0/1
MST10            24586 8843.e1bd.6a00  20000    2   20  15  Gi0/1
MST11            24587 8843.e1bd.6940  22000    2   20  15  Gi0/1
Reason:
XXXX-XXXX#sh int gi 0/1 | i dupl
  Full-duplex, 1000Mb/s, media type is RJ45
XXXX-XXXX#sh int gi 0/2 | i dupl
  Full-duplex, 100Mb/s, media type is RJ45
Actual my requirement is -
                                        Root Hello Max Fwd
MST11            24587 8843.e1bd.6940  22000    2   20  15  Gi0/2
Link goes down if i set it to 100 Manually.
Wait a second ... What is the exact model of your 2950 switch?
Model : WS-C2950T-48-SI
On the 2950, can you post the output to the command "sh interface g0/1 capa"?
282
