Webcast-Catalyst9k
Link over Fiber
I have dark fiber from Site1 to Site2 and from Site2 to Site 3, so Site2 is only a "bridge" site. My problem is that at Site3 I need to have separated T1's. The distance from Site1 to Site2 is around 50 miles, and from Site2 to Site3 is less than 30 ft. Can I go with a 2960 at Site1/ Site2 and from there to an IPMUX at Site3 (see attachment)? If yes how should I configure the 2960 and which SFP module should I use? Is that the best solution?
Thank you very much,
Liz
Everyone's tags (4)
Re: Link over Fiber
Untill and unless at layer 2 its ethernet from end to end, you should not have problem. For connecting devices using 2960 using fiber at a distance of 50 KM, ZX mode SFP is desired. i.e. 1000BaseZx which supports long haul distance upto 100 Km
Hitesh Vinzoda
Pls rate useful posts
Re: Link over Fiber
Liz
Liz,
With 30ft distance it wont be a problem with cisco 2960 switches,check out the below link on sfp modules with distance listed.
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6577/product_data_sheet0900aecd8033f885.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
329
