06-17-2010 10:05 AM - edited 03-06-2019 11:37 AM
Hello together,
we have a Catalyst 6509 VSS 720/10G System with IOS 12.2(33)SXI3 (IP Services SSH).
The Cisco MiB Locator shows that the LLDP-MIB is available for this system. But all
SNMP queries (v1,v2c) for LLDP-MIB variables shows no results? The LLDP
commands in the CLI work and give correct results.
Is there someting to mind if one will use the LLDP-MIB in SNMP queries (IOS configuration, SNMP
Version etc.) or gives der MIB Locator a wrong information or is this a problem of the IOS version?
Has anyone tried to query the LLDP MIB in a similar system?
with kind regards
Ulrich Werling
P.S: The same SNMP queries work well with correct results wit a Catalyst 3750E (IOS 12.2(50)SE3).
07-29-2010 11:06 AM
Giving this one a poke as I have a similar issue.
6509, 12.2(33)SXI4, Advanced IP Services, LLDP on and working from CLI.
08-09-2010 06:01 PM
i would also like the 6500's sup720 to support lldp reporting via snmp mibs.
08-30-2010 12:08 AM
Hopefully someone from CISCO will be able to let us have an answer on this. MIB Locator has misleading information
http://tools.cisco.com/ITDIT/MIBS/MainServlet?ReleaseSel=2514&PlatformSel=231&fsSel=705
10-19-2010 11:40 AM
We see the same issue in both Sup32 and Sup720/VSS configurations.
It would be a fantastic thing if LLDP worked over SNMP.
Eric
