Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
LLW Warranty RMA Delivery
Greetings!
We have WS-C4507R-E with LLWarranty upto Nov-2020.
One of power supply module is failed & need RMA. How to raise the RMA?
From which Depo of CISCO this RMA will be shipped? We need it in INDIA (IN)
Manoj
Hall of Fame Super Gold
"R-E" chassis are NOT covered
"R-E" chassis are NOT covered under Limited Lifetime Warranty.
Contact Cisco TAC.  Provide the serial number of the chassis and the part number of the faulty power supply.  If your chassis is covered, they'll ship a replacement power supply.
Hi Leo, But if check the
Hi Leo,
But if check the screen capture I have given for my serial number from CSCC Portal it shows its under warranty upto Nov-2020. What is this warranty then?
Warranty finder also says on
Warranty finder also says on LLW same. PFA snap
Could you please raise the
Could you please raise the case with Cisco?
Inayath
175
