Community Member
load balance outbound w/ NAT (router)
I want to make the balancing of outbound of two ISPs. I made the following configurations, but he did not function. somebody can help me?
int s0: ISP-1
int s1: ISP-2
eth0 10.10.10.1/24
mail server 10.10.0.2
proxy/ftp server 10.10.0.3
---------------------BEGIN--------------------------------
int eth0
ip address 10.10.0.10 255.255.255.0
ip nat inside
int s0
ip adress 200.100.200.2 255.255.255.252
ip nat outside
int s1
ip address 200.100.130.2 255.255.255.252
ip nat outside
ip route 0.0.0.0 0.0.0.0 200.100.200.1
ip route 0.0.0.0 0.0.0.0 200.100.130.1
ip nat inside source static 10.10.0.3 200.20.7.130 route-map ISP-1
ip nat inside source static 10.10.0.2 200.20.7.129 route-map ISP-1
ip nat inside source static 10.10.0.3 200.13.15.25 route-map ISP-2
ip nat inside source static 10.10.0.2 200.13.15.26 route-map ISP-2
access-list 101 permit ip 10.10.0.0 0.0.0.255 any
access-list 102 permit ip 10.10.0.0 0.0.0.255 any
route-map ISP-1
match ip address 101
set ip next-hop 200.100.200.1
route-map ISP-2
match ip address 102
set ip next-hop 200.100.130.1
---------------------END--------------------------------
thanks
Cleverson Ferla
Bronze
Re: load balance outbound w/ NAT (router)
You need to specify what kind of traffic has to be translated when you are using, ip nat inside source static 10.10.0.3 200.20.7.130 route-map ISP-1
Community Member
if you turn on CEF switching then your router should load balance per-destination across the routes you statically specified.
ip route 0.0.0.0 0.0.0.0 s0
ip route 0.0.0.0 0.0.0.0 s1
ip cef
if you want per-packet you can use the interface load-sharing command.
219
