load sharing internet with two router
I have Router cisco877 connect to ADSL, and route ENTRASYS connect to LL+,
the probleme that i need to share the connect to internet (backup)
thanks
Hall of Fame Super Silver
Re: load sharing internet with two router
Hello Armin,
you have a multivendor scenario
RIPv2 or VRRP are the possible options here
you can have RIPv2 running between the two routers and VRRP used to provide a virtual VIP to users in the lan segment.
see
for RIP
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_cfg_info_prot_ps6350_TSD_Products_Configuration_Guide_Chapter.html
for VRRP
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_vrrp_ps6350_TSD_Products_Configuration_Guide_Chapter.html
Hope to help
Giuseppe
Thank you Giuseppe,
but the problem that Router ENTRASYS don't support VRRP
please help
Hello Georgeo,
does the entrasys support RIPv2 ?
you can make use of the ICMP redirect concept:
if cisco router receives traffic it has to send to the entrasys it sends an icmp redirect to the host so that traffic for this destination is sent directly to entrasys.
you can enable it on Cisco router interface with:
ip icmp redirect
then all hosts should use as default gateway the Cisco router.
Hope to help
Giuseppe
thank you Guiseppe
the probleme that the router Entrasys don't support VRRP
thank you guiseppe
plz send me if you have some configuration example for ripv2 load-sharing
for information i have ospf in outside (Wan)
132
