11-13-2017 04:13 AM - edited 03-08-2019 12:43 PM
I have two ISP, primary line is 50 MB ILL, secondary line is 30 MB ILL connection, and also i'm using Cisco ISR4321 model router. the current configuration is primary ILL line configured in WAN0, secondary line configured in WAN1 port. and also VPN tunnel configured between two different locations, with the same Cisco ISR.
IF primary line down i have to remove unplug WAN0, then only secondary line gets wakup.
is there any possible to automatic wakup.
another one question, Is there any possible to use both bandwidth at the same time which means 50MB and 30MB at the same time.
i have to set up load balance, automatic failure line backup at the same time VPN also work.
Please advice
Sankar S
Solved! Go to Solution.
11-13-2017 04:26 AM - edited 11-13-2017 04:29 AM
If you are using BGP protocol at the edge, yes you could have load balance and use both Bandwidth at the same time. Now if you are using default static route you cannot but you can have an automatic failover, using: IP SLA, Object Track and EEM script in order to run a script once an event occurs, for example, it can delete the current default route and create other one with a different next hop (secondary ISP)
Hope it is useful
11-13-2017 04:27 AM
Yes you can do that with ip sla tracking , track a route upstream on primary circuit when it fails ip sla will auto switch it over , you can use it in conjunction with a route-map and ip verify reachability command
11-13-2017 04:36 AM
in addition to Julio's post, IF you do use static routing, you can achieve load balancing by configuring two (three is better) static routes. Since one link is 50MB and the other is 30MB, configuring two static routes for the same 50MB link and only one for the other link, would send more traffic down the first link.
Then, if one link fails, you could use an EEM script that removes the static route(s) to the failed link, and also clear the NAT translations for faster failover.
That said, we need to see your full configuration to decide what the best solution is...
11-13-2017 04:38 AM
Hello
Another more elegant feature would to be use PER ( Performance Edge routing) with this you can utilize both links based on the primary links utilization which at a certain % set by you can then automatically begin using the secondary link.
Have a read here to see if this would be applicable to you?
res
Paul
11-13-2017 06:09 AM
11-20-2017 10:40 PM
11-20-2017 10:40 PM
Hope it is useful
11-20-2017 10:40 PM
Thanks for your input.
Sankar S
11-13-2017 04:27 AM
11-20-2017 10:40 PM
11-13-2017 04:36 AM
11-13-2017 04:38 AM
Hello
res
Paul
11-13-2017 06:09 AM
