Loading IOS on 3750
tadkins67
I have a 3750-48-ts that I need to load the .bin image file into flash. I have no image file in flash currently. I've tried two different term emulators, connected to console to load it, but neither will pass the file to my switch.
8 Replies 8
ankbhasi
Hi Friend,
Are you in rommon mode? If you have an access to the switch you need to try tftp upgrade if your switch is in rommon then have you tried xmodem?
If you are in rommon have a look at this link
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00801cdee7.html#1099467
If switch is not in rommon then try tftp
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00801cdef7.html#1020606
HTH,
Ankur
*Pls rate all helpfull post
No access to switch. I've tried xmodem and that didn't work either. I"m using the following Cisco doc: http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a0080502445.html#wp1099467
Hi Friend,
While performing xmodem what error you are getting? Can you capture everything on hyperterminal and post it here?
Ankur
I get no errro. The dialog window appears that show my image to be received, but no packets/data is passed. My console settings are 9600, 8, none, 1, none.
Anand Narayana
Level 6
Level 6
you can upload using XMODEM console even if the IOS is deleted from the flash.
http://cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
Thanks for the article. I get the message now on my term session: "line to large" and it stops.
Troy
There also is an error msg that reads: "xmodem: bad file number"
Troy
It's working now. I was receiving instead of sending.!!! Brain lapse.
