Local DHCP snooping.
Can you have local DHCP on a switch then add a relay address on the SVI to back to ISE? Well I know you can do it configuration wise, but will it work?
HiYour post is a little
Your post is a little confusing.
So you want to enable a DHCP Pool for Vlan X on the switch but also add an IP Helper to the SVI pointing to an ISE which hosts an identical DHCP Pool for Vlan X?
Sorry for the confusion.I
I have VLAN X on Switch A. I also have a DHCP pool on Switch A for that VLAN. However I want to add a relay address just to pass the DHCP info to the Identity Services Engine.
71
