Local suspended VLAN Recovery on Nexus 5k
Dear All.
Is there any workaround to recover suspended VLANs automatically? They get recovered only on the peer-link, but not on the rest of vPCs.
I need either to bounce the interface or remove/add vlan on the host vPC, which is not a best solution.
SNALSIB101(config)# no spanning-tree vlan  201
SNALSIB101(config)# 2013 Oct 15 08:03:15 SNALSIB101 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 201 on Interface port-channel1 are being suspended. (Reason: Global compat check failed)
2013 Oct 15 08:03:15 SNALSIB101 %ETHPORT-5-IF_TRUNK_DOWN: Interface port-channel1, vlan 201 down
2013 Oct 15 08:03:15 SNALSIB101 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 201 on Interface port-channel4001 are being suspended. (Reason: Global compat check failed)
2013 Oct 15 08:03:15 SNALSIB101 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 201 on Interface port-channel10 are being suspended. (Reason: Global compat check failed)
2013 Oct 15 08:03:15 SNALSIB101 %ETHPORT-3-IF_DOWN_INACTIVE: Interface port-channel4001 is down (Inactive)
2013 Oct 15 08:03:15 SNALSIB101 %ETHPORT-5-IF_TRUNK_DOWN: Interface port-channel10, vlan 201 down
Gets recovered only on the peer-link:
SNALSIB101(config)# spanning-tree vlan  201
SNALSIB101(config)# 2013 Oct 15 08:03:20 SNALSIB101 %ETHPORT-3-IF_ERROR_VLANS_REMOVED: VLANs 201 on Interface port-channel1 are removed from suspended state.
2013 Oct 15 08:03:20 SNALSIB101 %ETHPORT-5-IF_TRUNK_UP: Interface port-channel1, vlan 201 up
SNALSIB101(config)# sh int po4001
port-channel4001 is down (inactive)
could you attach here the configuration?
Also, the following commands' output:
show vpc consistency-parameters global
show vpc consistency-parameters interface port-channel 4001
show vpc consistency-parameters interface port-channel 10
But, first of all try to shutdown/no shutdown the Port-Channel interfaces.
Best regards.
SNALSIB101# show vpc consistency-parameters global
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
IGMP Snooping Group-Limit   2     4000                   4000
QoS                         2     ([], [], [], [], [],   ([], [], [], [], [],
Network QoS (MTU)           2     (9216, 0, 0, 0, 0, 0)  (9216, 0, 0, 0, 0, 0)
Network Qos (Pause)         2     (F, F, F, F, F, F)     (F, F, F, F, F, F)
Input Queuing (Bandwidth)   2     (100, 0, 0, 0, 0, 0)   (100, 0, 0, 0, 0, 0)
Input Queuing (Absolute     2     (F, F, F, F, F, F)     (F, F, F, F, F, F)
Priority)
Output Queuing (Bandwidth)  2     (100, 0, 0, 0, 0, 0)   (100, 0, 0, 0, 0, 0)
Output Queuing (Absolute    2     (F, F, F, F, F, F)     (F, F, F, F, F, F)
Priority)
STP Mode                    1     Rapid-PVST             Rapid-PVST
STP Disabled                1     None                   None
STP MST Region Name         1     ""                     ""
STP MST Region Revision     1     0                      0
STP MST Region Instance to  1
VLAN Mapping
STP Loopguard               1     Disabled               Disabled
STP Bridge Assurance        1     Enabled                Enabled
STP Port Type, Edge         1     Normal, Disabled,      Normal, Disabled,
BPDUFilter, Edge BPDUGuard        Enabled                Enabled
STP MST Simulate PVST       1     Enabled                Enabled
Interface-vlan admin up     2     100                    100
Interface-vlan routing      2     1,100                  1,100
capability
Allowed VLANs               -     1,100,145-160,200-201  1,100,145-160,200-201
Local suspended VLANs       -     -                      -
SNALSIB101# show vpc consistency-parameters interface port-channel 4001
    Legend:
lag-id                      1     [(7f9b,                [(7f9b,
                                  0-23-4-ee-be-a, 8fa1,  0-23-4-ee-be-a, 8fa1,
                                  0, 0), (ffff,          0, 0), (ffff,
                                  18-3-73-4e-24-ab, 11,  18-3-73-4e-24-ab, 11,
                                  0, 0)]                 0, 0)]
mode                        1     active                 active
STP Port Type               1     Default                Default
STP Port Guard              1     None                   None
STP MST Simulate PVST       1     Default                Default
Port Mode                   1     access                 access
MTU                         1     1500                   1500
Duplex                      1     full                   full
Speed                       1     1000 Mb/s              1000 Mb/s
Admin port mode             1
Shut Lan                    1     No                     No
vPC card type               1     Empty                  Empty
Allowed VLANs               -     201                    201
Local suspended VLANs       -     201                    -
SNALSIB101# show vpc consistency-parameters interface port-channel 10
    Legend:
lag-id                      1     [(1, 0-23-4-ee-be-1,   [(1, 0-23-4-ee-be-1,
                                  800a, 0, 0), (7f9b,    800a, 0, 0), (7f9b,
                                  0-23-4-ee-be-a, 800a,  0-23-4-ee-be-a, 800a,
                                  0, 0)]                 0, 0)]
Native Vlan                 1     1                      1
Port Mode                   1     trunk                  trunk
MTU                         1     1500                   1500
Duplex                      1     full                   full
Speed                       1     10 Gb/s                10 Gb/s
Admin port mode             1
Shut Lan                    1     No                     No
I see a consistency problem on vlan 201.
First of all, review your port-channel configuration on both peers. If all are right, try to do this:
Conf
Vlan 201
State active
Good luck!
1435
