Local updater ID is 127.0.0.51 on interface EO0/0
I have a 6509 that is setup as a VTP server and my 3750 is a client.
I am getting "Local updater ID is 127.0.0.51 on interface EO0/0 (first interface found)" what is the meaning of this.
Core_Switch_2#sh vtp status
VTP Version : 2
Configuration Revision : 68
Maximum VLANs supported locally : 1005
Number of existing VLANs : 20
VTP Operating Mode : Server
VTP Domain Name : Hyderabad
VTP Pruning Mode : Enabled
VTP V2 Mode : Enabled
VTP Traps Generation : Enabled
MD5 digest : 0x0E 0xBA 0xE6 0x35 0x08 0x99 0x0F 0xB0
Configuration last modified by 127.0.0.51 at 8-22-09 06:08:19
Rgds.....Navinder
Hall of Fame Super Silver
Re: Local updater ID is 127.0.0.51 on interface EO0/0
Hello Navinder,
addresses like 127.0.0.51 are used for communication between modules on a C6500 chassis they are not allowed to exit the box as they are loopback addresses.
interface eo 0/0 should be for out of band management.
Hope to help
Giuseppe
Thank you for the vital information, however, as per our understanding in the "Configuration last modified by 127.0.0.51 at 8-22-09 06:08:19", the ip should be the ip of the port or Vlan from which the update has been done.
why I am getting 127.0.0.51 as the configuration last modified IP.
Rgds.....Navinder
684
