10-15-2010 05:34 AM - edited 03-06-2019 01:32 PM
simple test
PC(172.16.13.1) ---- switch (GW.100) ----- PC (172.16.14.10)
From PC 172.16.14.10, I can ping PC 172.16.13.1 when the dynamic entry has NOT been activated with the autocommand:
> ping from PC 172.16.14.10 to PC 172.16.13.1 WORKS ! WRONG BEHAVIOUR ! WHY IS NOT BLOCKED !
> ping from PC 172.16.14.10 to 172.16.13.100 or 172.16.14.100 fail (RIGHT BEHAVIOUR).
Only traffic to IPs on switch are blocked ... any communication to IPs outside switch is allowed even if the dynamic entry has not been activated!
If I activate the entry also communication to IP on switch (.100) works ...
Switch#sh access-l 101
Extended IP access list 101
10 Dynamic test permit ip any any
20 deny ip any any (164 matches)
Switch#sh ip arp vl 10
Protocol Address Age (min) Hardware Addr Type Interface
Internet 172.16.13.1 5 0004.764c.7eb2 ARPA Vlan10
Internet 172.16.13.100 - c84c.7585.c341 ARPA Vlan10
Switch#sh ip arp vl 20
Internet 172.16.14.10 0 0026.9e2c.cbc4 ARPA Vlan20
Internet 172.16.14.100 - c84c.7585.c342 ARPA Vlan20
Config:
username test password test
interface GigabitEthernet1/0/1
switchport access vlan 10
switchport mode access
interface GigabitEthernet1/0/2
switchport access vlan 20
interface Vlan10
ip address 172.16.13.100 255.255.255.0
interface Vlan20
ip address 172.16.14.100 255.255.255.0
ip access-group 101 in
access-list 101 dynamic test permit ip any any
access-list 101 deny ip any any
line vty 0 15
login local
autocommand access-enable
10-18-2010 06:13 AM
Let's start with basic issue:
On the switch, do an access-list:
Apply this ACL to interface to VLAN 20.
Try to ping from PC (172.16.14.10) anything: 172.16.14.100, 172.16.13.100, 172.16.13.1
It is working?
Cheers,
Calin
10-18-2010 06:27 AM
hi,
"normal" access-list works fine. If I configure your ACL to deny all traffic, traffic is blocked.
Dynamic ACL seems not to work correclty on 3750-x. Try my config and you will see !
I opened a TAC today about this issue !
10-18-2010 09:02 AM
I opened a case: dynamic ACL (lock and key) IS NOT SUPPORTED ON 3750, 3750E, 3750X ....
SEE BUG ID : CSCsv63203
no plans to support it >> see doc below !
Configuring IP v4ACLs on the switch is the same as configuring IPv4 ACLs on other Cisco switches and routers. The process is briefly described here. For more detailed information on configuring ACLs, see the "Configuring IP Services" section in the "IP Addressing and Services" chapter of the Cisco IOS IP Configuration Guide, Release 12.2. For detailed information about the commands, see the Cisco IOS IP Command Reference, Volume 1 of 3: Addressing and Services, Release 12.2.
The switch does not support these Cisco IOS router ACL-related features:
•Non-IP protocol ACLs (see Table 36-1) or bridge-group ACLs
•IP accounting
•Inbound and outbound rate limiting (except with QoS ACLs)
•Reflexive ACLs or dynamic ACLs (except for some specialized dynamic ACLs used by the switch clustering feature)
•ACL logging for port ACLs and VLAN maps
