Lock Rogue Dhcp server from switch level best pactices
Please let me know the best practices to prevent rogue dhcp server inside network.
Let me know cisco have any tools to monitor the same from switch level
Re: Lock Rogue Dhcp server from switch level best pactices
You will need to implement (DHCP Snooping) and trust DHCP on the required uplinks and access ports.
Another way is to check (IP Source Guard) Feature.
Please have a look at the attached document.
Mohamed
Thanks Mohamed. Is this feature available on all models
Our model is 2600 series at layer two level .
Hall of Fame Super Silver
Hello Rajeesh,
on several platforms are available security features like dynamic ARP inspection.
On the basis of DAI ip source guard and DHCP snooping are possible and the latter is the specific tool to use to fight rogue DHCP servers.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_46_se/configuration/guide/swdhcp82.html
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_46_se/configuration/guide/swdynarp.html
Be aware that if you enable DHCP snooping the default state for all ports is untrusted so you need to declare trusted the access ports where a legitimate DHCP server is connected and the uplinks from which another switch can see legitimate servers answers.
Hope to help
Giuseppe
295
