10-30-2006 01:51 AM - edited 03-05-2019 12:30 PM
Can anyone explain me the differnces among them.As per my understanding SNMP is used to send snmp traps to the NMS.
Please help on this issue.
Mahmood
10-30-2006 02:13 AM
Hi there,
This all depends on your setup. If you're logging to host, then it will send the system messages that you have specified in the logging "level" - ranging from 0 - 7 (informational to debug), 7 being the highest.
SNMP traps are a different thing. They will fire off a trap to a host when an event happens or a threshold is reached.
They are similar in that if an interface goes down, then the node will log a syslog event and send a trap (if configured to do so). However, the log message will be a message and the snmp trap will send a trap including the OID (object identifier).
You can do a LOT more with snmp than you can with log messages, such as send messages when an interface hits more than 50% load, etc.
Oh - there is a command so that you can send log messages as snmp traps too ;-)
Hope that helps a bit,
LH
Please rate all posts
10-30-2006 04:25 AM
SNMP is the Simple Network Management Protocol.The SNMP protocol is used by network management systems to communicate with network elements.
Every Time when a incident happen, all are logged in the local Device. These logs can also be sent to a seperate syslog server.
Daniel Massey
