01-02-2007 03:12 AM - edited 03-05-2019 01:33 PM
I am not getting interface status messages like interface up or down in any logging(buffer,console or terminal)
All are enabled with level 7
The IOS is cat4000-i5s-mz.121-20.EW4
Is it a known issue???
01-02-2007 03:33 AM
Hi Friend,
Can you try enabling
"logging even link-status" under interface config mode for that particular interface
You can also set it up for global config to take effect on all the modules and interfaces
Conf t
logging even link-status global
Also make sure you have "terminal mon" configured to see these messages on telnet session.
Try this and I believe it should work.
Ankur
01-02-2007 09:18 AM
Ankur, I believe this command is not supported in the current IOS that the poster is running "cat4000-i5s-mz.121-20.EW4 ". You need atleast 12.2.25SG to run the " logging event link-status " command under the interface.
Tahseen, Please check if you can run that command and let us know.
I think to solve this problem, you need to upgrade your switch to IOS 12.25SG to run the commands as posted by Ankur and also check the link below:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_25s/cmdref/int_sess.htm#wp2089249
HTH,Please rate if it does.
-amit singh
01-02-2007 06:57 PM
Ankur/Amit
See what u r saying is fine but I would like to tell you that whenever i shut interface manually and make no shut i see the log messages counter increasing by 2 which is right but it doesn't display message,Any comment
Also thanks for the info
01-02-2007 08:25 PM
Tahseen,
We both agree with you on this. You see the counter incearing under the interface but you dont see " link up/down" log neither when you console nor when you telnet/ssh to the switch. This was a problem in earlier versions that the IOS wasnot logging the link up/down messages, which has been rectified in IOS 12.2.25SG by introducing the command" looging event link status " under the interface mode or in the global config mode.
You are running an older version of IOS in the switch, so I am in doubt if that command is supported.You can upgrade the switch to atleast 12.2.25SG and then use the command as listed and you should be fine with it.
-amit singh
